So you are looking for a touch screen, if i guessed right.I suggest this one: https://www.amazon.com/Juvtmall-Display-800×480-Function-Raspberry/dp/B072558KZ4/ref=sr_1_17?ie=UTF8&qid=1543493179&sr=8-17&keywords=raspberry+pi+touchscreen
P.S i recommend you buy a Raspberry Pi 3 instead of Pi 2
