Planning out a build in a Node 202, but I'm wary of the temperature issues, especially since I will be using a Gtx 1080ti in my new build. I'm going to be gaming on an ultrawide 1440p 144hz monitor so I'm not worried about my CPU temps, but I would like to find a way to overclock my 1080ti. My first idea would be to take off the stock cooler use a Nzxt g12 and a Thermaltake tundra slim 120mm rad and fan to cool the card. However, I'm not sure if this will fit. Looking for input from the community and any ideas I may have missed. Thank you in advance guys!
https://linustechtips.com/topic/1001492-node-202-gpu-cooling-solution/
What 1080ti is it to begin with?
10 minutes ago, Josh_Top said:
Asus strix gtx 1080 ti
Well, the cooler on that is fairly decent to begin with
But for the G12, the 202 barely has anywhere to even put a radiator and probably isnt worth your time and money for a few degrees *IF* you can squeeze it in there
