Security Problem
Solved by Snipergod87,
Block access to the task manager, stop the users from running .exe's from non approved locations (GPO will by default only allow C:\Windows, C:\Program Files, and C:\Program Files (x86) if you enable those settings), so if they download process explorer it cannot be launched. as they should not have write access to any of those directories.
These settings are configurable group policy settings.
You should probably prevent booting from USB flash drives completely as well and secure the BIOS with a password.
