Need Help Streaming with OBS
Go to solution Solved by now254,
Hey, i am using encoder x264 for my streaming, that work the finest for me and 1920x1080 res, inn some games i turn the fps down on the output too the stream too 30fps for bether stream quality but and even 720p (1240x720) inn the worst cases ,  less demmanding games i run 60fps out
my best suggestion is too try and fail experiment with your setup
Need Help Streaming with OBS what is the best settings for me to stream so that i can have a good quality stream image and smooth fps no pixels or blurs
My Main PC specs
Intel core i5 3470 3.20GHz
16gb ddr3
GTX msi nvidia geforce 1050ti
64-bit OS
Windows 10 pro
My internet is the ds.jpg.69fb2230852bf2f3c8a09b83341c64ca.jpguks number one broadband service virgin media fibre optic 350mbps download speed and 20mbps upload speed
https://linustechtips.com/topic/1000978-need-help-streaming-with-obs/
Probably 540p30fps at like 1200-1500 kbps or maybe 720p30fps around 1600 kbps (very fast to ultrafast preset). Your CPU will definitely be a limiting factor, you have plenty of internet. You could also try stream labs OBS or NVIDIA shadow play, both have slightly lower hits to performance (shadow play more so).
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
