Need GPU HELP
Go to solution Solved by Crunchy Dragon,
This is what Bungie says: https://www.bungie.net/en/Help/Article/46853
Download DDU, boot into safe mode, and use DDU(https://www.wagnardsoft.com/) to clean out your drivers. Then download the new driver from Nvidia's site: https://www.geforce.com/drivers
All my games keep crashing for reasons i can only say are my nvidia 1060 drivers. The game i play the most are Destiny 2 and Rainbow 6 siege. In Destiny 2 i can play for about 30 mins after my computer boots up then it crashes , if i reload the game it will crash with in 10 mins. With Rainbow 6 it will freeze and then not respond giving no error.
I posted the destiny error report in the image
Thing i have Tried
Reinstalling drivers (Failed)
Doing a custom (clean install) (Failed)
manually uninstalling all nvidia installs and restarting multiple times then reinstalling drivers (Failed)
Yes i did install the New update to day for nvdia (FAILED)
also Windows is up to date.
https://linustechtips.com/topic/1000468-need-gpu-help/
https://linustechtips.com/topic/1000468-need-gpu-help/#findComment-12010271
DIDNT WORK RIP
https://linustechtips.com/topic/1000468-need-gpu-help/#findComment-12010560
1 hour ago, PlexNicoli said:
DIDNT WORK RIP
I hate to say this since I know firsthand how big of a download Destiny 2 is, but try reinstalling the game.
https://linustechtips.com/topic/1000468-need-gpu-help/#findComment-12010854
