I left my device for a while, got back to it last weak it didn't post without cmos clear everytime I turned it on
I thought a bios update could help so I did update the bios the progress bar done then it went ahead to restart but it didn't post but since then clearing cmos no longer solved the issue it just doesn't detect the ram Which I know that they're fine I tried multiple ram configs ,same problem cpu and ram ez debug leds 3 beeps after turning on
system specs
ryzen 5 1600
msi b350m gaming pro
2*8 gskill aegis 3000mhz
xigmatek 750w 80+ silver
no oc was applied
help plz
https://linustechtips.com/topic/1000369-need-help-with-pc-not-posting/
Maybe it isn't saving the BIOS file because the battery on the mobo is dead?  Just an idea.  Looking at the error codes for 3 beeps, could be ram or motherboard, depending on whether it is AMI Award BIOS or something else.  If possible, might want to check out this website.  https://www.computerhope.com/beep.htm
I tried a couple of different batteries no differance
You got a pack of dead memory modules, try talking with the company you have bought it from and try to get it RMA'd.
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
I craiglisted one of em last year and the other last weak . They were working just fine before the bios update so I don't think they died because of it
