I'm going to upgrade my PC with a few new parts (keeping my storage, PSU, CPU Cooler if possible) I already bought a GTX 1070 so that's a part I'm going to install anyway. Since this is kind of my first build I'd like to know about some parts and their compatibility.
Budget & Location
Budget: 450 US$ / 400€ + flexible Case Budget
Aim
I want to run games like:
-Monster Hunter World
-Destiny 2
-Overwatch
Being able to run most games in general
Monitors and Peripherals
got everything I want.
Why are you upgrading?
Games don't run that smoothly anymore on my FX-8350 and GTX 970
This is my current list of parts I would've bought (including the PSU, Cooler, GPU I already have) :
PCPartPicker indicates that the Cooler may require a seperate mounting adapter to fit the motherboard. Hope you can help me with that.
Thanks in advance and sorry for any spelling or grammar mistakes :(
https://linustechtips.com/topic/1000174-need-help-upgrading-my-pc/
Get the 2600 non X or a 2700 if it's not much more than the 2600x.
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
4 minutes ago, LukeSavenije said:
Thanks for your suggestion, I still have a few questions:
Is the Motherboard going to be compatible with my cooler?
What do I get for the 40€ spent extra on the motherboard?
1) yep, it's am4 compatible
2) much better vrm's, and a top tier board in general
3 hours ago, LukeSavenije said:
I just did some research and found out the Ryzen 5 2600 seems to perform better than the 7 1700 concerning gaming. Why did u chose the 7 1700 then?
The extra 2 cores. More games are getting optimised for 8c/16t
