Thermaltake Riing 12 RGB installation help
Solved by W-L,
10 minutes ago, justin2926 said:This is is probably a stupid question but how do you install a thermaltake riing 12 rgb onto an inwin 301? I’m using the short screw and it doesn’t want to screw onto the fan. I’m scared to force screw it in. The instructions are only for how to plug it into the fan controller.
If they are the small self tapping screws they can take a bit of force since they need to cut the threads directly into the plastic frame.
