Using an EEG Electrode with an Arduino
Guest
I'm trying to get my own brainwaves from an eeg electrode. I found this blog of someone converting an electrode connector to an arduino connector (what are they called?) My question is instead of the OpenBCI board that he made this for, could I use it with an Arduino board?
blog post: http://eeghacker.blogspot.com/2013/11/making-eeg-electrode-adapter.html
openbci: http://openbci.com/
Technically you would be able to do it. You would have to use ADC and connect electrodes to the ADC input and connect ADC's digital output to Arduino. You can even use the same ADC as the openbci guys - ADS1299 with desired amount of input channels.
Id say you could, but you wont be able to simply just plug the electrodes into the arduino.You will need circuitry to amplify and clean any signal or all you will get will basically just be white noise.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
