24inch monitor mount
onemanarmy720
what is a good monitor mount for two 24 inch monitors, i want it to clamp onto my desk and be under $50.
was thinking this http://www.amazon.com/VIVO-Monitor-Adjustable-Screens-STAND-V002/dp/B009S750LA?ie=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=A3W3STWCK1O3NR
CPU: I7 8086K                              MOBO: Gigabyte Z370 Aorus Gaming 5   RAM: 16Gb G-Skill 3200mHz
GPU: GTX 1070 FE 8GB            CASE: Phanteks Enthoo Evolv ATX           OS: Windows 10
PSU: EVGA 650G                      SSD: 250GB Samsung Evo                       HDD: 1000GB WD BLUE
You should look up the model of each monitor and check whether or not they are VESA-mount compatible. This would allow you to find a wide range of mounts.
Thy hath sinneth, and in thy life thou hast fallen to an unholy, unspeakable level of humanity. Thou hast given into your basest needs. And suffered many years under thine Satan-box. However, if thine be willing, as thy hast show yourself to be, thy can ascendeth into thy glorious fold of the glorious church. Go well, my brother, may your temps be low and your frames high. ~ MrDynamicMan
yes they are VESA mountable
If you search for VESA clamping mount on Google, you may find what you want. It's up to you to judge what matches your desires.
