Crackling audio
Go to solution Solved by Lappan95,
Seems to have fixed the issue by disabling my CPU from down clocking in the bios, weird that the cpu downclocking to 800mhz would cause it.
Hi after I purchased my new GPU: Asus GTX 1070 Dual OC and Case: Corsair Carbide 200R I've been getting crackling audio from my Sound Baster Z pci card.
Tried switching to different pci slots, even the second 16x slot, fresh install of drivers, fresh install of windows, wiped my GPU Drivers and installed the latest ones, tried only installing the Nvidia graphic drivers, updates to latest onboard audio drivers, disabling the onboard and NVIDIA High defenition audio through device manager to no avail.
This issue can randomly come and lasts until I enable "spatial sound windows sonic" and then disable it. Then it's all gone until it comes again.
Anyone else has a clue what I can try next?
Edit: Onboard audio works fine without any issues, it's only when I use my Sound Blaster Z card it happens.
Specs are:
CPU: Intel core 6700k
MB: Gigabyte gaming k3 z170
Ram: Corsair Vengeance 16gb DDR4 2400MHz
PSU: Evga supernova g2 650watt
https://linustechtips.com/topic/999878-crackling-audio/
Specs are:
Replace the sound blaster z?
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/999878-crackling-audio/#findComment-12005052
Going to try it in another PC tomorrow to rule it out if it would be faulty.
This probably has nothing to do with your error message, but I had an issue with the onboard audio of an older system.
Horrible static/crackling. Nothing I did made a difference, changed out speakers, new drivers, etc. Nothing.
Turns out my power supply was quietly dying and couldn't provide enough power to my system. Removing the video card, freed up enough power that the sound returned to normal. So, a new PS was in order and all was well with the video card back in the system.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/999878-crackling-audio/#findComment-12005113
Ive had this issue numerous times. Uninstall your sound driver and then reinstall it.
With Great Power, Comes a Great Electricity Bill
Main
Setup: Intel core i5-8400 (OC'd), MSI Z-370-A Pro, Crucial Ballistix 8GB, Be Quiet! Pure Slim, Cooler Master Masterbox Lite 5 RGB, TP-Link Wifi Adapter, ASRock RX580, Artic Silver 3.5g Thermal Paste, Logitech G105, Logitech M310, Razer Sphex V2 (Mat), EVGA 500W 80+ Silver, 1TB WD Blue, 240gb Kingston Digital
https://linustechtips.com/topic/999878-crackling-audio/#findComment-12009635
