So, i have an Samsung Galaxy J3 2017 (SM-J330F/DS) and i want to ask some questions about a problem.
When i try to play any game on my phone, the phone just randomly restarts. This happen everytime.
That started to happen after last system update
my operating system is Android 8.0 (Oreo) (baseband version J330FXXU3BRI3)
I tried the next things. Factory reset, wipe cache from recovery
I want to try next. Factory reset without the sd card (maybe is a virus on it idk)
The Phone warm up a lil bit (and apps for temp says it's 60 C (celsius) when i play a game i can play aprox 10 min and then restart, the way it manifest tell me that is an system crash)
I have to mention that this problem occur only in games and in other apps even those that need plenty of resources that problem doesn t occur
The questions are:
Is a hardware problem, or an software problem?
What is the problem that cause this to occur?
What can i do to fix this?
Do i need to downgrade to android 7 to fix this problem? (using a custom rom and then wiping the system and writing the old android 7.0)
Please help me because this problem really bothers me
https://linustechtips.com/topic/999842-system-crash-problem-android/
Has it had any water damage at all? My old Pixel XL had this exact same issue due to water damage from my job.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
i have to mention that this problem occur only in games and in other apps even those that need plenty of resources that problem doesn t occur
Hmm I would imagine the phone it's self is overheating to the point were it feels the need to shut down and restart to unload the system and give a tiny bit of time to cool down.
|King Of The Lost|
i thought that too but what can i do to fix this problem?
sometimes it reaches 70 degrees (celsius)
Have you removed the sim card to see if the LDI(liquid damage indicator) is any other color than white? Cause this kinda sounds like the exact same issues I was running into with my LG V10 and my Pixel XL
|King Of The Lost|
i will try now. what do i actually need to se?
Look down into the sim slot there is a white sticker you should be able to see with probably some light, if its any color other than white(Red, pink or purple) it has liquid damage.
|King Of The Lost|
it's a white sticker with 2 red X's
So zero water damage then. Those only thing I could assume is hardware failure starting.
|King Of The Lost|
6 minutes ago, Lonewolf6869 said:
what can it be the affected component?
Processor sometimes they use thermal pads or thermal paste to make sure the phone can transfer the heat through the body of it. But downgrading won't probably do much at all.
|King Of The Lost|
maybe this android it s too much for this phone. (it s the oficial upgrade but still)
They wouldn't push it to the phone if it was to much for it to run.
|King Of The Lost|
um... i just solved it by formating the sd card and then reset the phone? and not restoring the things from cloud backup? so i think somewhere was a virus?
