Hi, I bought an additional GTX 1080TI for my configuration today.
I have this SLI bridge included  with my motherboard:
9-C236100-750-A-4-F9-C-8-E52-AE8-D6-C359
Can you tell me, i need another one like this for 2way SLI ?
Or do I need buy a new one like that ?
Case: Corsair iCUE 7000X RGB Black
Motherboard: Asus ROG CROSSHAIR VIII FORMULA
CPU: AMD Ryzen 9 3900X running at 4.5GHz
RAM 64GB G.SKILL TridentZ RGB Neo AMD DDR4 3200MHz
GPU: MSI Nvidia RTX 3080 TI Suprim X 12GB
Sound: Sound Blaster Audigy Rx
Storage: 2x Samsung NVMe 256GB  2x 256GB Samsung SSD PRO
Storage:  2x 8TB Seagate HDD
Cooling: NZXT KRAKEN Z73
PSU: ROG THOR 1200W Platinum
Monitor: LG 32UD99-W 4K + LG OLED 55" 120HZ 4K
Speakers Set: Logitech Z-906 THX 5.1
Laptop:
MacbookPro 13 (2016)  || MacbookPro 16 Core i9 2.4 and 32 GB DDR4 on 1TB SSD || Lenovo Legion Y540-17IRH with i7-9750H 32GB QVO2TB GTX1650-4GB
Server Lab:
Lenovo ThinkServer RD350 with 120GB DDR4 on 2x Intel Xeon E5-2609 v4 on Esexi or Proxmox
Network:
Hitron CGNv4 modem (Stock) || Linksys WRT32X (OpenWRT) || Mikrotik RB2011UiAS-2HnD-IN (OpenWRT)  || UniFi Security Gateway PRO USG‑PRO‑4 || UniFi Cloud Key Gen2 Plus || UniFi Switch 48 US-48-500W POE
https://linustechtips.com/topic/999237-2x-2way-bridge/
That’s a high bandwidth bridge. Recommended for the 10 series and high resolution.
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12000470
You can do any option, run one, run two or get th fancy bridge. Won’t really matter.
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12000482
OK, so what bridge do I need for connect these two 1080TI ?
Laptop:
Server Lab:
Network:
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12000486
What do you mean by "no matter" ?
So what for are these two SLI slots on 1080TI ?
Laptop:
Server Lab:
Network:
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12000494
You can do what ever you want. One bridge. Two bridges or a high bandwidth bridge.
Originally they designed them to support 3/4 way sli. Thus you need two fingers.
If you think your system can achieve the supposed 2-3 frame increase from two bridges or a high bandwidth bridge, get one.
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12000524
Mick, 2-3 frames ? You make some test with one one and two bridges ?
Laptop:
Server Lab:
Network:
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12001003
No I didn’t. I don’t have a cpu strong enough to handle to cards in any test.
But plenty of youtubers have. The page you’re on for instance, had a video covering this.
https://linustechtips.com/topic/999237-2x-2way-bridge/#findComment-12001069
