I recently purchased my 1050ti and I installed it today, with the old version - which runs perfectly normal, and I don't mind.
I decided to upgrade my version, so I visited the Nvidia website, and selected 416.94 and downloaded and rebooted my PC, it restricted my resolution to 1600x1200, and it also had a error in the device manager - and it didn't work? Now I am pretty disappointed about this and any help as to why this error has happened would be really appreciated, here's my PC specs
AMD A8-7650K
16GB DDR3 Ram
Nvidia 1050ti
MSI Grenade Motherboard
https://linustechtips.com/topic/998839-1050ti-issues/
did you use DDU to remove the old drivers first?
Desktop benching:
https://linustechtips.com/topic/998839-1050ti-issues/#findComment-11997785
And I forgot to mention, I play some games such as Farming Simulator 19, or Gold Rush and my game seems to crash when my graphics are set at high and usually any other games but Farming Simulator crash, and Farming Simulator crashes when graphics at put to high.
https://linustechtips.com/topic/998839-1050ti-issues/#findComment-11997788
13 minutes ago, Will_172 said:
I used to have a onboard GPU until I installed the 1050ti.
I think it might be causing issues, it was an onboard AMD R7 graphics card
yup, you need to use DDU to get rid of old drivers first.
better remove both AMD and Nvidia graphics drivers for now, then reinstall it.
Desktop benching:
https://linustechtips.com/topic/998839-1050ti-issues/#findComment-11997840
okay, so i woke up this morning and want to wipe my old drivers.
please could anyone give me instructions?
i have a disk that goes into the pc disk tray and it loads the nvidia installer software, and it gives me a old driver, so once i wiped the amd and nvidia driver would i run that, get the old driver then go to their website, update the nvidia driver but what would i do with the driver that came from the disk installer? would i delete it?
https://linustechtips.com/topic/998839-1050ti-issues/#findComment-11999791
First download the latest driver from Nvidia's site and save to desktop for later use.
Download DDU: https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Disconnect WiFI/Ethernet so Windows doesn't connect to the web and download a driver you don't want.
Restart Windows into safe mode and run DDU, use clean and restart option.
Once back into Windows install Nvidia's drivers.  I would use latest from the site and not the disc you have.
Ryzen 2600 - Sapphire Pulse Vega 56 - Corsair Vengeance LED DDR4 3000 C15 2x8GB - Corsair Force MP500 NVMe PCIe M.2 240GB - 2x Seagate Barracuda 2TB -
AsRock B450 PRO4 - Deepcool Earlkase Case -  Seasonic Foucus+ 650
https://linustechtips.com/topic/998839-1050ti-issues/#findComment-11999847
Thanks for your help but I have ran into another issue - my 1050ti now has error 43 - and I believe it is not selected as the GPU for my computer, Windows might have overwritten it? Please help
https://linustechtips.com/topic/998839-1050ti-issues/#findComment-11999992
