I'm going to be doing a new build using a H500M & a ML360R to overclock a 8600k.
The H500M has 2 200mm fans in the front, 1 120mm fan in the back.
Since I would be adding a cooler with 3 more 120mm fans - I have these options.
#1 Put 3 fans up top. Radiator on top. 4 Sub Options.
             - Fans can sit under the radiator (push or pull)
             - Fans can sit on top of the radiator (top of case) (push or pull)
#2 Put 3 fans up top. Radiator front of case behind 200mm. 2 Sub Options.
             - Fans can either push or pull
#3 Radiator front of case, fans sit behind it. (Double Intake) 1 Option.
Seeing a lot of conflicting ideas here on what is most optimal.
I was thinking if I did radiator front of case - remove the RGB fans and relocate them to top of case - then you'd have the 200mm fans pulling air into the radiator, and 4 exhaust fans. Or, since there's a dust filter on the top - I can pull in air from the top as well, and use 1 exhaust. While cooler master seems to promote that setup, It does seem like a poor setup due to warm air rises (if that matters here) and dust settling on top of the case when OFF.
Thoughts?
https://linustechtips.com/topic/997824-optimal-setup-using-cooler-master-case-aio/
