Figured it out. It's because at light workloads, only a couple of the cores are used, meaning it'll turbo high. However, pretty much all modern cpu's run slower when utilizing all cores. As you can see here under general specs: https://en.wikichip.org/wiki/intel/core_i5/i5-6400 an all-core turbo is 3.1 Ghz, whilst 1 or 2 cores is 3.3 and 3 cores is 3.2.
https://linustechtips.com/topic/997346-cpu-problem/#findComment-11986155
Oh okay thank you very much but is there anyway to make it work better for gaming?
https://linustechtips.com/topic/997346-cpu-problem/#findComment-11986164
