I have a budget of 1000$ and I am pretty experienced in the pc world having many IT friends but have never build any pc’s myself. I am also pretty familiar with parts of pc’s so, I have a challenge for all of you. Build me an intel or amd pc on pcpartpicker.com that can run all 2018 games at 1920 x 1080p at 100FPS or higher very high/ultra settings. Thermals are very important to me so please make this pc run cool by adding good fans/parts as well. Rgb doesn’t matter to me at all. Also if you really can’t work with a strict 1000$ budget don’t be afraid to break the budget by 30-50$. Thank you very much to anyone that helps!
https://linustechtips.com/topic/996593-help-me-with-first-build/
10 minutes ago, Slottr said:
Why the single 500gb ssd instead of the classing 240gb SSD + 1/2 tb HDD combo tho
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
Just had it in there from another build I sent someone, could also do that
17 minutes ago, Slottr said:
Add an ASRock X470 Fatal1ty K4 ATX motherboard instead of that MSI piece of crap. The rest of the build is fine though.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Is it? I've heard good things in passing, I'll keep that in mind
Pretty much all MSI motherboards use crappy VRMs with the exception of a few high end boards.
Oh gotcha. Wasnt aware that was still an issue regarding the B450 boards.
