currently building a 3D Rendering/Animation/Video Editing PC
Here's my 2 build, the only difference is the amount and the speed of the RAM.
https://pcpartpicker.com/list/LLPJGG (2x16 2666MHz)
https://pcpartpicker.com/list/wdbpMZ (2 x 8 3200MHz)
so which one should i get?
added question should i get a Quadro P1000 or K1200 or should i stick with my GTX 1070?
https://linustechtips.com/topic/996416-help-me-choose/
  • I'd maybe look into a better PSU.
  • You have a K chip with an H series motherboard; you need a Z series motherboard to overclock. Or get a locked CPU.
  • You can get a 1TB EVO for $129 on Black Friday. Well worth the extra $30.
How much more is 32GB of the 3200mhz?
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/996416-help-me-choose/#findComment-11978619
Quote
Looking into that, I'm considering buying the be quiet straight power 11 650W 80+G, I'm not from the US so i don't have a lot of options.
Quote
the 32GB 3200MHz is way out of my budget, that's why i'm asking if i should get the 2*8 3200MHz or 2*16 2666MHz cause they're both about the same price.
Quote
Thanks!
https://linustechtips.com/topic/996416-help-me-choose/#findComment-11978667
get a weaker cpu and go for a pro gpu, honest if your gonna a gaming gpu amd is better for CAD atleast in silverworks
I may be wrong.
https://linustechtips.com/topic/996416-help-me-choose/#findComment-11978674
