Hello
Just yesterday I got a Sapphire Nitro + OC RX 580 4GB as a gift. Originally I had RX 480 4GB from Asus. And I had no problem. But, when I played with RX 580 few games, monitor suddenly went into sleep mode. And I can´t do anything, but only restart the pc. This problem was solved.  But when I set the POWER mode or stealth mode in the Sapphire program, it goes back to sleep mode. It's not that often, but it happens. I tried to change HDMI,ports, no change. I think this is a problem with PSU ?
My specs:
MB: Asrock b350m pro4
Processor: Ryzen 1600 stock
RAM: 8gb
PSU: Corsair CX450M
SSD: WD Green 3D NAND 240GB
HDD:  Seagate BarraCuda - 1TB 7200rpm
https://linustechtips.com/topic/996084-rx-580-psu-problem/
7 minutes ago, MichalCin said:
Should reinstall windows to rule out any software issues. could also try flashing the bios to the latest one for the RX 580.
Did you win a giveaway or something? because a 480 to a 580 isn't even an upgrade, and if the PSU handled the 480 just fine then I don't know why it would suddenly have issues.
If you want to test it with less stress on the PSU just turn the power target down to 50%
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976017
@Streetguru
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976035
2 minutes ago, lmeneses said:
Should return it for the cash if that's an option...was my point...
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976044
My friend won two graphics,so he gave me one as a gift. I had ASUS DUAL RX 480, and this graphics runs hot and very loud. I had to lower the temperature to 75 in afterburner.
Ok. I first reinstall windows.
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976062
Oh but that is a good point
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976063
3 minutes ago, MichalCin said:
Well you could always get a new PSU anyways and do crossfire assuming the board has 2 slots.
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976081
That´s good idea. What PSU do you recommend 650-750W?
Probably this one from EVGA assuming it has enough PCI-e connectors, it's also on sale looks like.
https://pcpartpicker.com/product/2BcMnQ/evga-power-supply-210gq0850
https://linustechtips.com/topic/996084-rx-580-psu-problem/#findComment-11976106
