I just ordered a 1440p 144hz (OC to 165hz) monitor and it uses display port which I have no experience with. It is probably a silly question but to get 1440p at 165hz will the cable that comes in the box be good enough or will I need to get a different higher bandwidth one?
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/995632-display-port-question/
If they sent you a cable it should be good enough. Of course, no harm in just plugging it in and finding out
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/995632-display-port-question/#findComment-11972583
Just use the one in the box, that's what it's for :)
https://linustechtips.com/topic/995632-display-port-question/#findComment-11972584
