My parents recently found an old laptop From 2009. I got the hard drive and I put it into my computer. When trying to look through the hard drive the folders take forever to load. (I have given Administrator access) I want it to be faster because I want to get the photos off of it and I also want to plug my other hard drive back in. It just takes forever. Its only 60 gb
https://linustechtips.com/topic/995218-slow-hard-drive/
Kinda SOL, a slow hard drive is gonna be slow
You could put it into a system that has an SSD or faster drive in it with windows and just plug it in, but its still gonna take time
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968561
2 minutes ago, Slottr said:
Kinda SOL, a low hard drive is gonna be slow
You could put it into a system that has an SSD or faster drive in it with windows and just plug it in, but otherwise its gonna take time
2 minutes ago, Andrew.Schickowski said:
its most likely just the age of the drive and its slow rpm
Its weird because some folders open quickly but the ones that need administrative access take time
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968578
Just now, SHG_Marsh said:
Its currently in my PC right now.
Best you can do at that point then
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968580
OPTANE BABY!
just kidding it would be a waste
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968595
Just now, fasauceome said:
OPTANE BABY!
Nah, 32gb of suPeR fAsT drive space is worth a million dollars
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968600
1 minute ago, SHG_Marsh said:
Should I replace my current drive with the other one so I can just go onto the drive and move the files or would that be bad for my pc
I don't think that will work but you're welcome to try, it won't hurt anything.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968609
2 minutes ago, SHG_Marsh said:
I meant to say make it my boot drive. Would that do anything? Because now it is connected to my pc with a sata cable
yeah I don't think you'll be able to boot into it, I think the existing OS will lock you out, but you can certainly try.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968631
I just restarted my computer and it automatically went into automatic repair mode. I couldn't even get into my bios.
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968711
Ok probably time to yank the old hard drive
Primary PC:
PSU tier list
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968717
Boot from a Linux USB and use that to copy the files over because Linux doesn't care about NTFS permissions.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/995218-slow-hard-drive/#findComment-11968948
