Just bought Fallout 76; The game is constantly running between 30-60% GPU usage. When I open task manager the GPU usage jumps to 100% for a really short period of time. I tried different drivers that didn't make a difference.
The rest of the system is
4 GHZ 2700
3466 RAM that does have the ability to run Memtest for days without a single error; really.
I don't think it is any bottle neck because the CPU usage is under 40%.
https://linustechtips.com/topic/994906-low-gpu-usage/
They'll have to patch it, the day one included fixing a glitch that had to do with the framerate dictating physics. Are you getting 60 fps?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/994906-low-gpu-usage/#findComment-11965794
