Hi! I recently built a computer and have had this really strange audio error. I can't fully describe it because it's so strange, but here's kind of what its like: if I go to change the volume level from the home menu on Windows, it will play the little ding noise as normal. However, as it fades away the volume grows slightly quieter and gets staticy. I've noticed it also happens during bassey sounds in games, such as the sound of reinforcing walls in Rainbow Six Siege. I have seen nothing online for how to fix this, so baisically anything you guys could tell Mr would help. Thanks!
https://linustechtips.com/topic/994073-static-sound-during-audio/
What type of speakers / headphones are you using?  Have you tried multiple types?
Are you using the ports on the motherboard, or a front panel?
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
You should probably buy a DAC/AMP if the static noise bothers you a lot, although a good one does cost a decent amount of money.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
I'm using the ports on the front panel, as I cant get my audio port on my mobo to work for some reason. The microphone works however. I'm using the Razet Kraken V2, and I have tried different headphones. I'm thinking it might be my case as it was rather cheap, but I kinda feel like that can't really happen. I dont know for sure though.
