Is their any water blocks anywhere at all that support the Gigabyte GeForce GTX 1070 Ti Gaming 8G? I have been looking for a while and I cant seem to find anything, if anyone knows of anything that would be great if you could post a link. Thanks for any help.
Main And Only Build : CPU : Ryzen 5 1600x (OC to 4.2GHz), Cooler : Thermaltake Floe Riing RGB 240 TT Premium Edition, Motherboard : Asus ROG Strix B450-F Gaming, RAM : Trident Z RGB 16GB (2*8) 3000Mhz DDR4, GPU : Gigabyte Gaming GTX 1070 TI, PSU : EVGA G3 650W 80+ Gold Certified, Storage : 250GB Samsung 860 Evo + 256GB SU800 + 2TB Seagate HDD.
https://linustechtips.com/topic/993282-water-block-support/
Does not seem like a reference design card. Most blocks are made for reference design cards as making a block for every custom card design is not economically viable.
Some manufacturers partner up with waterblock makers for custom blocks but you need to buy it as a unit usually like the gigabyte waterforce range of cards
https://linustechtips.com/topic/993282-water-block-support/#findComment-11951157
