17 hours ago, Txe said:
Does anyone know of a 4pin eps cable comb (cablemod)  because i cant find one
They sell them as kits but any 3-4mm comb will fit onto their cables. The larger 4mm for the Modflex material.
https://cablemod.com/product-category/cable-combs/
https://linustechtips.com/topic/993167-solved-cable-combs/#findComment-11952748
Sorry since there was no 4 pin (square) cable comb I decided to just get a aftermarket cable combs and cut off an existing 8pin cable comb to a 4 pin one but thanks any way
https://linustechtips.com/topic/993167-solved-cable-combs/#findComment-11952758
