help- vpn is blocked
Solved by looney,
thanks for the quick responses
i already have looked at dd-wrt, but as my linksys_xxxx supports vpn and services such as dyndns.org and 1 other ddns service
i will have to look up Tor, but i want to be able to game and use skype at the same time, so i dont want toooo much lag
i would put the router at home and set it up as a server, and get vpn client software on my laptop at school... or wouldnt that work?
As long as it uses openVPN that will work, most other VPN's will still be blocked as the use a port that isn't 80
