Does anyone know how this actually works, I have activated it in Geforce Experience, and also adjusted the setting in the global settings, but it seems to done a whole load of Jack-Sh*t To my computer or the supposed Frame Throttle ( i set it to 70fps and it still running at 90fps) WTH is the point of it if it wont even work! the reason i am even using the feature is because my laptop Sits at 95C under load so i wanted to cool it down, and it does nothing!!
Any advice?
https://linustechtips.com/topic/991102-nvidia-wisper-mode-advice/
Any advice?
Updated drivers?
1 hour ago, Aprilfooldude said:
Is the fan curve set properly?
Even at full 6000RPM on both, its still overheating, its why im trying to reduce the load on my GPU as i dont need it to be trying to run games at 120 fps when im happy with 70 until it goes back to the Factory for repairs. If i restrict it in game to 60, its till Pinned and smoking hot
Find my Cooling profile here of what i HAVE done so far to reduce it with no success at all, still pulling 90C most of the time
Attempt to reinstall the NVIDIA drivers and restart your computer, that may make a difference.
1 hour ago, Ben Quigley said:
Install afterburner and reduce power limit to 70%
It's a max-q chip I doubt it's possible
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
1 minute ago, TokiToki said:
its greyed out, how do i do that?
Have you disabled whisper mode?
