Problem with graphics card and display.
GPU fans stopping is normal.
List your specs please
10 minutes ago, jgw said:
Whenever I attempt to turn on my pc, the case and cpu fans. However my graphics card fan spins for around 30 seconds before the fan stops. Also I am not getting any display and therefore no boot, please help me.
Modern graphics cards will completely shut the fans off if the GPU is:
  • Not hot enough (~60*C before they turn on?)
  • Idling in Desktop, or under low usage
As for the no display problem, make sure your monitor is connected to the back of your graphics card, and NOT to the motherboard.
As @Slottr mentioned, information about your system would be super helpful, too.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
