laptop CPU cooling
Solved by Jurrunio,
3 minutes ago, Turboswordsman said:Is upgrading a cpu cooler in a laptop worth trying?
no, unless you don't mind the laptop being stuck to a desk.
4 minutes ago, Turboswordsman said:and if so will doing that reduce the cpu usage?
if the clock speeds go up thanks to extra cooling and the amount of work per unit time stays the same, then yes
