My Logitech G933 has gotten loose power button over time, and when the button slides forward and back it distorts the audio, removes right side audio occasionally and this really destroys the listening experience. (So much so that I've begun just using my monitor's speakers temporarily). I've looked it up online and this seems to be a frequent issue with this headset.
I've tried removing the left speaker and reattaching the connection to the power button, but it didn't fix anything.
There are no other apparent issues with the headset, but this is big enough to prevent normal use of them.
Any tips to fix this?
Edit: Well it doesn't really slide forward and backward that much, not like it turns on and off, but it's very wiggling and loose.
https://linustechtips.com/topic/988191-g933-distorted-audio/
