15 minutes ago, FRNND_P said:
I have unalocated space in a my drive but it wont let me extend my C partition
Any suggestions?
Please send a picture of the partition table. There may be another partition infront of the main partition.
https://linustechtips.com/topic/987406-cant-extend-volume-c/#findComment-11896159
First, download MiniTool Partition Wizard as SSD Sean said. Then, start the program, right click drive D, choose the Move/Resize function to change the location between this partition and the unallocated space. After that, the unallocated space should be after partition C, you can then reopen Windows Disk Management and directly take the unallocated space to extend partition C, this is the fastest method I know.
https://linustechtips.com/topic/987406-cant-extend-volume-c/#findComment-11909298
