Depends on the results that you want. If you found something that you could sleeve the cables in without having to disconnect the ends then go for it. Or do and easy one and one proper sleeved cable. That should give you an idea of time and looks.
Asus Maximus VI Hero , i5 4670k , 8gb Corsair vengeance ddr3, Asus HD 7970 matrix platinum, Corsair AX860, Ocz agility 3 120gb ssd, 1tb wd green hdd, custom water loop. All in an Antec p280
https://linustechtips.com/topic/9872-cable-sleeving/#findComment-107071
