Laptop problem
Solved by akialwayz,
Just now, Spock_1701 said:
i did that before no drives show up
then I'm afraid its a hard disk problem.You could try removing the Hard disk out of the laptop and check it on another pc to see if it is working or not.but mostly you might have to replace it.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
