i need help with finding and CPU and MOBO for my build and also an reliable PSU
here is a list of parts i already decided on -
Case - COOLER MASTER CHASSIS MASTERBOX Q300L
Cpu - 100$ - 120$
Gpu - asus gtx 1060 6gb OC
MoBo - about 75$
HDD - Toshiba 1TB 600Mbps sata III,250gb ssd
Ram - corsair vegenance 1x8gb
PSU - 40$ max
I am going to use this build for playing games like Fortnite , CSGO , BO4  on high settings, and streaming.
I am located in Latvia and i am going to order my parts from Amazon.de and 1a.lv (a local site)
My Full budget is around 670 euro.
I really appreciate your help!
Edit:
Heres a PcPartPicker list
https://linustechtips.com/topic/986763-first-build/
For CPU, get a Ryzen 2600 or an i5 8400. For PSU, get a Corsair CX450M (even if it's a bit more than $40).
BTW, can you provide a PCPartPicker list of your PC (it really helps us find components within your budget).
You can save some money by getting a RX 580 8GB instead.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/986763-first-build/#findComment-11889725
I would definitely try and get a Ryzen 2600 even if it means you have to downgrade the gpu a bit. Could go with a RX 570/80 if there are any deals.
Fortnite and CSGO can run alright on a weaker cpu like a ryzen 3 or 5 2400g but BO4 won't fair too well so it all depends how much future-proofing you want.
https://linustechtips.com/topic/986763-first-build/#findComment-11889748
https://linustechtips.com/topic/986763-first-build/#findComment-11889800
12 minutes ago, LegendFrosty said:
Get a CX450M PSU as I said above, and get a Ryzen 2600 CPU
https://linustechtips.com/topic/986763-first-build/#findComment-11889854
