I have decided to go with the Logitech G 703 wireless and I have a few questions.
*Will there be a noticeable difference in performance on FPS such as fortnite for how it responds as it's wireless. if so will it be better to go with a G 403?
*How long does it last each charge and how long does it take to fully charge
*Is the sensor good enough (I don't want it to spin out as I move fast when I build) My current mouse spins out 3-4 times each lobby.
*How long will this mouse last (Years)
*Is this a good choice.
Any help with these questions is well appreciated  : ) thanks
        Current PC
CPU: I5-7400
GPU: Gigabyte 1050Ti
RAM: Crucial DDR4 8GB 2133mhz
CASE: GameMax Falcon
MOBO: Prime B250M-A
                                       Peripherals
Mouse: Corsair Sabre
Keyboard: Corsair Strafe
Mic/headphone: Blue Yeti /w JVC HA-SR50X
Mouse Mat: Razer Goliathus
https://linustechtips.com/topic/986523-mouse-help-g-703/
Well... mice don't contribute to your frames per second so... If you mean input lag, everything that's wireless is inherently slower than wired.
Don't know. You can buy a Logitech power play mouse pad and it will last indefinitely. If you want to spend $100 on a tiny mouse pad.
Both it and the G403 (and many other mice) use the PMW3366 sensor which is basically the best sensor on the market right now. No it won't do flips and shit
Depends how many times you throw it, cause wireless mouse don't stop when the cord reaches it's max length.
"Good" is subjective. I will most likely never use a wireless mouse for gaming. Just my taste. It's also really expensive. A G403 is 40% cheaper and is literally the same thing with a wire. It will also be lighter, something that most people like. Not all though.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887431
Hello! I actually just bought this mouse about a month ago!
1. As far as I have had it the sensor is excellent, no problems what so ever or input lag.
2. For me, I have both the scroll wheel light and Logo light on full brightness all day. I would say it lasts about a day and a half for me and it charges to full in a little less than an hour.
Honestly I can see this mouse lasting me a good couple years, and just in case I bought a 4 year warranty for 10 dollars from Best Buy which is where I purchased it from.
In my opinion I love this mouse and if you have somewhat big hands and are right handed this is a great choice!
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887434
@Wazy Do you use the mouse on fortnite? and how does it feel in FPS games?-----   @Cereal5 Thanks for the reply I was lead to believe the G 703 has lightspeed (Not a clue what that is) I would have thought It would be better due to it being newer. Also is the G 403 a better option?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887453
Yes I do play Fortnite, at least a couple hours a day, it's great to able to build without having to worry about the wire, and as for FPS games I don't really feel any difference, it works great and feels great to hold. Also when they say "LightSpeed" they are referring to the mouse being wireless. As for choosing whether to buy the 403 or the 703 it really comes down to whether you don't mind playing a premium fee for wireless. They are the same exact mouse just one is wireless and the other isn't.
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887463
@Wazy Well the G 403 is 40 pounds and the G 703 is 55 pounds. Would you say it runs as good as a wired mouse? Have you had any problems with it ingame such as not responding to certain things?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887471
@Wazy Also my hand size is 18cm from palm to fingertip and across its 9cm I use Claw and Fingertip. Do you think the mouse would be good for this?
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887476
Thanks for you're help I'v decided to go for the G 403 due to how may pro players use it for different games so it means its a half decent mouse also It's cheaper so If it was to break its easier to replace. Thanks @Wazy For you're help I will be getting the 703 next year.
        Current PC
CPU: I5-7400
MOBO: Prime B250M-A
                                       Peripherals
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887492
I'm gonna be honest, I don't even know my own hand size lol, all I know is that I have the biggest hands in my family. As for the grip I use Palm and it feels great, and I would definitely say that Claw is great for this mouse. Although any Grip is perfectly fine.
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887493
Hey no prob dude, just know that with either choice you happened to choose either would have been a smart choice, these are great mice.
https://linustechtips.com/topic/986523-mouse-help-g-703/#findComment-11887496
