Hi LTT forum,
so I’m currently working on a job for a client and setting up a few systems that will be tucked away, i can only say so much NDAs and all that but, basically these systems cant use internet to connect out and then be managed but they need to be remotely managed becasue they will be tucked away in a secured room don’t need anything to advanced just basic control. The systems arent to me yet and i cant really test on them I don’t have enough systems to test so turning to the community for help. I had a couple of ideas (listed below) some feedback and/or suggestions would be really appreciated. Thanks in adavance!
Maybe a network that isn’t connected to the internet itself so just a secured closed network to control the systems?
If that wont work Ethernet into a switch to create a lan network?
Please any siggestions would be greatly appreciated, thank you!
https://linustechtips.com/topic/986286-remote-desktop-offline/
I would think cheapest would be wifi router for servers and laptop with wifi. run remote desktop listener on the servers and use a remote desktop app on pc/laptop/tablet/phone
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
https://linustechtips.com/topic/986286-remote-desktop-offline/#findComment-11884910
So if I understand right this would work without actual service? This system has to be closed loop just confirming this would work so as long as my devices are on this network then it will work. Thanks!
https://linustechtips.com/topic/986286-remote-desktop-offline/#findComment-11884974
