This is during a furmark stress test on a GTX 1080 Strix. Why is it not going to my boost clock?
System Specs
GPU - Asus ROG Strix GTX 1080
CPU - Intel i5 8600k @ 4.8Ghz
Motherboard - Asus ROG Z370-F Gaming
Ram - G.Skill Trident Z RGB 16GB 3000Mhz
Cooler - NZXT Kraken x62
PSU - Corsair RM550x
Storage - Samsung 860 EVO 250GB / 1TB Barracuda
Case - NZXT H500
https://linustechtips.com/topic/984575-gpu-not-going-to-boost-clock/
Max out your power limit and temp limit.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
Looks like it is to me. Whats the temp? Have you used a real bench mark like unigine?
Not at all, temp has not passed 63 in my tests.
I'll look into that benchmark.
System Specs
Case - NZXT H500
So where is the power and voltage at along with the actual fan speed?
Thing is, I literally just fac reset my pc before this happened, I used stock voltage / auto aswell as fan speed and it hit 2ghz, im rlly not sure whats happening.
It's still on auto rn.
System Specs
Case - NZXT H500
Well it shouldn’t effect the card but you could put the pc on high power of not already. Could fresh install an older driver or uninstall the msi software and see how it reads in the actual benchmarks.
Furmark hit 2025 for a bit, I assume its just not demanding enough of my GPU.
System Specs
Case - NZXT H500
 I wouldn't know, I quit using the donut of death in 2012. But theres not reason it shouldn't be able to boost in every benchmark.
