R7 2700x (4.3ghz), Gtx Titan Xp Galactic Empire (Watercooled), 2x8 Gskill Trident 3200mhz, Asus Crosshair VII Hero Wifi, Corsair 900D, SAMSUNG 960 PRO M.2 256gb, Samsung 850 evo 500gb, 4x3tb 7200rpm Segate Barracudas in Raid 10 EKWB Custom Loop, Corsair AX1500i Power supply
https://linustechtips.com/topic/984523-x-flow-rads/#findComment-11869393
I mean is their a particular reason you need xflo opposed to a standard rad?
https://linustechtips.com/topic/984523-x-flow-rads/#findComment-11869430
9 minutes ago, mrcalcutter said:
shorten my loop down massively it isn't a must but it if the option is there.
I mean the issue is those kind of rads increase the overall size due to 240mm being already used for the radiator fins alone then using space for the ports on each side opposed to condensing to one side and the other empty. The only thing you could really do is either do a single 120mm rad or just use a normal 240.
https://linustechtips.com/topic/984523-x-flow-rads/#findComment-11869447
