I've read plenty that this was a problem with drivers around 382-384ish, but I just encountered it now. I have an MSI 1080 Ti Gaming X, and I was experiencing some odd GPU problems (namely not downclocking at idle, and almost complete inability to overclock), so I decided to do a clean install of drivers, since I didn't when I installed the card a couple weeks ago (upgraded from a 1080 FE). I booted into safe mode, used DDU to uninstall the driver (which was 416.34, the most recent), then restarted, downloaded GeForce Experience, and reinstalled driver 416.34.
After install, I right clicked on the desktop, and NVIDIA control panel wasn't there. I opened MSI afterburner, and it wasn't reading the 1080 Ti. So I restarted, Afterburner picked up the new driver, but still no control panel. I tried re-uninstalling and re-reinstalling the driver, and same deal. I went into the NVIDIA Corporation file folder to look for the control panel file manually, but couldn't find it anywhere. I tried installing an older driver, but GeForce Experience is weird and wouldn't let me do that. So... I'm kind of at a loss of what to do. I started this all mostly cause I just wanted my GPU to go down to idle clocks (I started a trouble shooting thread about that a couple days ago but got no helpful responses lol). Does anyone know of anything I can do?
Thanks
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/984345-nvidia-control-panel-missing/
Try uninstalling GeForce Experince and downloading the latest driver from Nvidias site. Then when installing, make sure that you only install the driver and not also GeForce Experince then perform a clean install in the custom install options. See if that helps :)
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
It forces me to download GeForce Experience before installing the driver, and then installing the driver through GeForce Experience.
Strange... When first installing the driver you can un-check the checkbox for GE, did you do that?
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
"The Standard NVIDIA graphics driver is not compatible with this version of Windows. Please update your driver using GeForce Experience to download the correct version."
That's what I get every time. So I have to go redownload GE, and install the driver there
Weird. Did you download it from here? (I assume you're running Windows 10)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Yeah. Tried both the geforce website and the stock nvidia one (the one you linked)
Hm. Can you send screenshot? Currently in the process of downloading a driver for myself so I can see if it says the same.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Yep. I got the same... Could be because the new Windows update... God dammit Microsoft........... ?image.png.3a75cb973798e82971bc64a9ed537545.png
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
I JUST WANT MY CONTROL PANEL
cries Why does this have to be so hard
You can try rolling back to the 1802 build, but you're probably gonna lose some files...
No thanks. Definitely not for a "maybe" solution
Ok then. Have you tried installing it when in safe mode? (Doubt it'll work, but worth a shot)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
No, but I did the original uninstall in safe mode. I don't see how that would affect anything though...
How about installing it through Device Manager?
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
No. I will have to try that tomorrow (today), but it just pulls the driver off the internet so... I don’t know I’ll try it
Not if you choose the "Browse my computer for driver software" and so on...image.png.2bbac5d053b11abea40750581d38afbe.pngimage.png.9a55cc7fbfeef451c13105d9465c203d.png
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
Yes I forgot about that... now I can choose between the 5 different downloads of the driver I have lol. Will try
Also had a new driver update through GE. You CAN perform a clean install through GE. Just click custom install :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
I know. I tried more than once.
12 hours ago, Uptivuptiz said:
Did it work?
Nope.
2 hours ago, Cereal5 said:
Nope.
R.I.P. Well looks like you gotta wait for a patch... If anything you can try contacting Nvidia support.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
