Corsair Lighting Node Pro cables
Go to solution Solved by kontradictions,
I hate to say it but I made my own. Here are the parts you'll need as well as 24 AWG wire.
3-pin Female connector: (Molex  50-57-9403)
Found here: https://www.digikey.com/product-detail/en/molex-llc/50-57-9403/WM2901-ND/115034
Pins for Female Connector: (Molex 16-02-0102)
Found here: https://www.digikey.com/products/en?keywords=16-02-0102
3-Pin Male connector: (Molex 70107-0002)
Found here: https://www.digikey.com/products/en?keywords=Molex 70107-0002
Pins for male connector: (Molex 16-02-01143)
Found here: https://www.digikey.com/products/en?keywords=16-02-0114
On the 2nd picture you posted, that's the female connector. White is your negative, red is data, black is 5 Volt power. You don't need a crimping tool, I made mine with a pair of needle nose pliers and wire strippers.
Anyone know where I can find some replacement cables for my Lightning node pro?
I'm in the UK
Please don't say make one yourself
I've looked everywhere
These cables should only be a few quid a pop
Closest I've found for the 9 pin USB motherboard header to mini usb B port:
https://www.moddiy.com/products/USB-Internal-9%252dPin-to-Mini%252dUSB-Adapter-Cable-%2860cm%29.html
I've not even come close to finding the 3 pin female to 3 pin female connector which must include something they refer to as "anti reverse" which are basically clips so they don't come out and click in place
Pic of what I mean:
Image result for 3-Pin Anti-reverse Cable For Arduino
Anyone got any spares they wish to sell?
Thanks
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
https://linustechtips.com/topic/984131-corsair-lighting-node-pro-cables/
