I'm experiencing an issue where my DP doesn't detect any input, but my HDMI does and on top of that I have no option to enable G-sync. Life is great
Specs:
Monitor: ASUS ROG SWIFT PG279Q
PC:
ASUS ROG STRIX Gaming Z370-E
Intel Core i7-8700K (stock atm)
MSI GeForce GTX 1080ti Gaming X
Corsair Vengenance 3000, 16gb kit
Windows 10 Home, 1803
I have tried turning off the computer and unplugging evrything and waiting a few minutes  before plugging in again, still doesn't. I don't know why g-sync isn't working and I can't find anything online. I am using the DP that came with the monitor. Would appreciate any help.
EDIT: After the 4th time of unplugging evrything and waiting half an hour it finally let me display through DP. The G-sync problem is also solved. Apparently you can't have G-sync while displaying through HDMI Sorry for having to post, but it was a brand new 2000$+ so i was becoming desperate. Have a nice day.
https://linustechtips.com/topic/983229-having-a-problem-with-my-setup/
Maybe a stupid question, but have you changed input in the monitor settings from HMDI to DP?
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
So, you don't get an image on one of your monitors?
If so, Do you know if the port on the GPU and monitor work? And have you tried a different display port cable?
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools - Douglas Adams
