Dear Forum users,
I recently bought a 2018 bade to replace my old PB laptop for work, but I have had a lot of issues with the thunderbolt/ usb c port. As when ever I plug my iPhone 7 Plus in then remove it using apple own usb c cable it blue screens my laptop every time without fail.
Any thoughts on what this issue could be?
Just a note I can't see the error issue as it reboots faster than my eye can see.
https://linustechtips.com/topic/983216-razer-blade-2018-issues/
Have you tried using "safely eject this device" first for luls?
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/983216-razer-blade-2018-issues/#findComment-11856445
record it using slow-motion camera of your iPhone?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/983216-razer-blade-2018-issues/#findComment-11856485
51 minutes ago, NormalHades2604 said:
Dear Forum users,
Could be an earthing fault in the cable, might be worth trying a different cable if you can to rule that out first.
https://linustechtips.com/topic/983216-razer-blade-2018-issues/#findComment-11856517
Dear Chronified, Firelighter487 & Sky_Shark_101,
1) I have tried using iTunes eject for my iPhone but it still blue screens, I don't know another eject for iPhone is you do please let me know.
2) I have tried but it even is to fast for that.
3) I have had apple replace the cable twice and it still blue screens.
I have a feeling it might be a motherbord issue.
https://linustechtips.com/topic/983216-razer-blade-2018-issues/#findComment-11856721
Hi NormalH
I am assuming you have tried this before but did have you followed those the steps before removing the cable ? Especially Step 2?
Step
Look at the status bar at the top of the iTunes window. Wait for any process to finish or click the "X" beside the status to stop the current process.
Step
Click the "Eject" button beside the iPhone in the list of devices. Wait for the iPhone's name to disappear.
Step
Safely disconnect the iPhone from the computer's USB port.
Ejecting an iPhone in Windows
Step
Move the cursor to the upper right corner of the Windows 8 desktop and then drag it downward to reveal the desktop sidebar. If you have a touch screen, drag your finger to the right edge of the desktop. Select "Settings" and then "Change PC Settings."
Step
Select "Devices" and then select your iPhone from the list of devices. Click or tap the iPhone's "Remove" icon and then select "Remove."
Step
Safely unplug the iPhone from the computer.
https://linustechtips.com/topic/983216-razer-blade-2018-issues/#findComment-11876279
