  • Check different components. Unplug the GPU, most of the RAM, any of the unnecessary Drives.
  • Check that the power switch is plugged in correctly.
  • unplug the CPU power and try and power the board on, if it does, you've got a bad CPU
You essentially want to test the computer where there is only 1 possible reason for it not to work and that's your problem.
https://linustechtips.com/topic/982533-slight-issue/#findComment-11850864
Check all cables. Specs?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/982533-slight-issue/#findComment-11850866
