Yesterday I cleaned my PC by taking out GPU card and all.. I had removed the fan which is on the GPU and placed it back..
After the system turned on I found PC working was slow and display was wired too... So my friend suggested to update the GPU driver I did it and was proper and I restarted the PC then again It was looking wired... I have attached the image plz let me no the solution and what has may has caused for this...1539411285619-59723085.thumb.jpg.d4cd950a531d158953cb56edab4ba02b.jpg
https://linustechtips.com/topic/982376-plz-help-me/
Speaking of wired, have you plugged all the pcie power cable back into the card and everything else? Plugged in the fan cable to the card?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/982376-plz-help-me/#findComment-11850003
