I changed my desk around and maintenance of dust screens is becoming a annoyance. Is airflow of components needed really? Or should I just wall mount my pc? Gpu's/Cpu are on water. Only thing needing air is cpu vrm's? I have the stuff around to wall mount it for less then 10$, where a decent case is 100-200$, The case I'm using is pretty modded/cheap.
https://linustechtips.com/topic/982350-wall-mount-vs-new-case/
In general everything in the PC should get some incidental airflow but you can get a monoblock if you want to cover the cooling needs of the VRM's.
https://linustechtips.com/topic/982350-wall-mount-vs-new-case/#findComment-11849905
