UPS - How to pick?
Go to solution Solved by vanished,
1 minute ago, Hi P said:
Uninterruptible Power Supply
1.- What do you look for when picking one?
-enough wattage
-enough runtime
-pure sinewave output, particularly if you PSU isn't great
-a variety of other smaller factors depending how much time you want to spend researching
2.- What's the most reliable brand for UPS?
Probably one you won't be buying.  As for the common desktop ones, CyberPower and APC are common.  I tend to think APC is better but I'm not sure.
-enough wattage
-enough runtime
https://linustechtips.com/topic/982242-ups-how-to-pick/#findComment-11848835
10 minutes ago, Ryan_Vickers said:
-enough wattage
-enough runtime
Get one that has some kind of signal when it switches on as well. You don't want to be blissfully unaware of a power outage, and continue happily using whatever you need the UPS for until it dies.
https://linustechtips.com/topic/982242-ups-how-to-pick/#findComment-11848860
Good advice, but probably not something that will eliminate a lot of options.  On mine, even with my very closed headphones on and music playing relatively loudly, I can hear the relay kick on.  But, if that wasn't enough, the loud beeping every few seconds certainly would be, and I think this is a feature any good one would have.  They also offer the ability to connect to a program on your computer which depending how it works could notify you, or automatically hibernate to avoid a improper shutdown, etc.
https://linustechtips.com/topic/982242-ups-how-to-pick/#findComment-11848864
3 minutes ago, Hi P said:
I have the 600 W PFC model.  I think it's good, but I'm no expert on these.  Personally I'm still weary of non-sine wave models but it can be fine depending on the situation.
Another question, is it safe to use on rainy days?
I don't see why it shouldn't be.  Just don't put the unit in the rain directly xD
https://linustechtips.com/topic/982242-ups-how-to-pick/#findComment-11849064
