Are you overclocking the GPU at all?
What version of GeForce driver are you running?
have you run Display Driver Uninstaller and reinstalled the latest drivers?
I recall there being some discussion about PUBG and a certain GeForce driver problem some time ago.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833153
GPU is running on stock
newst drivers ,manualy downloaded and installed with Display Driver Uninstaller,aswell with geforce expirience
it was aswell crashing in heaven benchmark tool
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833162
what does the history look like before it crashes?
System specs:
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833169
I am usiting it atm and its all normal surfing/listening youtubel,its just when i load my graphic card,i tryed heaven benchmark tool,pubg ,csgo and it always just freezes
sorry for my bad English
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833178
Just now, scottyseng said:
I would try a different PSU. I had an issue in my server where the 1080 Ti would crash under any load, but it turns out my PSU went bad.
so there is no way its GPU fault for crashing?I am wondering becouse i bought it used.
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833301
It's possible, but that would be odd for a six month old GPU. But yeah, never know, your luck could just be bad.
Yeah, for me I had put my used 1080 Ti in my server but it would keep crashing, under any GPU render load. Indeed the PSU had gone bad (Or at least it didn't run well at higher load).
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833315
Okay thanks,i will tomorrow go to pc shop to check with new PSU
Btw. is it safe to use PC with this PSU and GPU atm or it could go something wrong
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833331
Here's the thing. GPUs either work, or they don't.
not as in, "hey i will POST your system, and i can perform small load stuffs, but if you put a heavy load on me i'm going to crash LOL!" but rather in "I turn it on, and i get black screen, no POST, like, at all." vs "I turn it on and the computer POSTs"
It is all or nothing.
This is a software issue.
System specs:
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833333
So u think PSU is good enough?Can u give me some tip what to try
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833346
I would still try PSU first, but make sure the store gives you full refund just in case.
You should step through a checklist, like:
Run CPU stress test (I use Intel Burn Test)
Run memory test (memtest x86)
Swap PSU
Swap GPU for something else
Have to just start working through a list until you find what's wrong. For me it was PSU. The GPU would run fine at idle, but crash when any gaming load was applied. It would run through vray rendering well. My 980 Ti did the same in the server, so I knew it wasn't the GPU. Once I swapped the PSU in the server with the one in my PC, no issues at all.
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833399
The GPU is only going to pull about 250W from the 12v rail, I doubt your system pulls more than 150W extra. It's possible the 12v rail on the PSU is not quite up to to the task and the card is going into lower power state.
System specs:
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833403
Swap PSU
i have my old GPU( http://www.inno3d.com/products_detail.php?refid=18 ) and it work perfetcly fine,but when i swap with this GPU its crash on load,i tryed some bad 600w PSU and its was all same,even on same sceen its crash on benchmark tool
https://linustechtips.com/topic/980681-1080ti-freezing-problem/#findComment-11833412
