Hi
I have a hp ssf pre built that i got for a little project. Most so i can run into problems with out waiting any realy money and get my knowledge up.
This pc has a 25w limet on the pcie.
I disided to get a 1030 d4  (please i know is a rubbish card but it will definitely work and fit in the case and for £40 used did not seem too bad)  20w tdp any way what arived was a low profile dd5 30w tdp.
Due to personal issurs it card and system will not be in the same place until after the return date.
I was wondering if i cobble together powerd with a pcie extention and uses the and the 4.
Or its there something you can do with software to underclok it
Or any elce that would cost less than £20
Or any one in the Dovon  England  with a h2 socket motherboard in for cheap
https://linustechtips.com/topic/980596-hp-ssf-graphics-card-help/
