Will this pc build work
Go to solution Solved by Agonizel,
Your 3000£ PC will work yeah
I'm just not a fan of the PC Case, the airflow is terrible. Instead, since you're using a 360mm AIO, I'd recommend the Lian LI O11 Dynamic instead.
I'd recommend 2 sets of 3x HD120s/LL/ML RGB fans on top and bottom. and the 360 rad with the stock fans on pull config on the side.
Or if you wanna go full illumination, I'd use HD120s on the bottom & rad - and LLs on the top. No RGB strips needed.
Good luck!
Good luck!
RGB & Fan control ULTIMATE GUIDE !
https://linustechtips.com/topic/980224-will-this-pc-build-work/#findComment-11829393
27 minutes ago, blank_apple said:
Is there anything dumb I don't have in my pc build planning. My planning is on the excel document
Corsair.xlsx
Build this instead...
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  (£439.94 @ AWD-IT)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  (£68.99 @ Amazon UK)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  (£142.97 @ More Computers)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  (£125.99 @ CCL Computers)
Storage: Crucial - BX500 480GB 2.5" Solid State Drive  (£64.19 @ Aria PC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  (£50.34 @ Aria PC)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB SC Black Edition Video Card  (£667.47 @ Scan.co.uk)
Case: NZXT - H500 (White) ATX Mid Tower Case  (£68.98 @ Aria PC)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£85.47 @ Amazon UK)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  (£82.97 @ Laptops Direct)
Monitor: Asus - MG278Q 27.0" 2560x1440 144Hz Monitor  (£399.99 @ Aria PC)
Keyboard: Corsair - STRAFE RGB Wired Gaming Keyboard  (£99.59 @ Aria PC)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  (£59.89 @ Amazon UK)
Total: £2356.78
Generated by PCPartPicker 2018-10-07 13:16 BST+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/980224-will-this-pc-build-work/#findComment-11829451
