I recently built my first gaming PC, which worked fine for 2 weeks but now getting BSODs frequently.
I have some questions:
1) do i need z series board in order for RAM to use XMP profile
2) can ram overclocking cause BSOD
I have got two sticks of 8gb Corsair Vengeance 2400mhz but in BIOS one shows 2133 and other 2400
I have tested my ram using memtest86 and it sometime shows error and sometime not, i am really confused.
https://linustechtips.com/topic/979895-ram-overclocking-bsod-help/
1) depends on the motherboard's BIOS, but you usually can. Running 2400MHz profile when you have a stick that's only good for 2133MHz though is a bad idea. You're pushing it into unknown territory.
2) Yes, definitely
go back to the store and tell them their sticks dont match their on-box specs.
Desktop benching:
2) Yes, definitely
BSOD usually occurs after 12-14 hours of work, and the ram i have is also not on QVL of motherboard, does it make any difference ??
no difference. Unlike CPU overclocking, memory stability isnt guaranteed so easily.
Desktop benching:
8 hours ago, 5ir5ly said:
maybe there is a faulty stick, if its 2400mhz ram outta the box and you have the xmp set for that, it should be fine, try removing the stick that reads at 2133mhz and see if you have the same issues...
i removed and tested both of them, actually its the 2400mhz stick that causes issues, system freezes on and off while playing game.
what to do now.?
Try moving the sticks to slots A1 and B1. Can you change the ram speed to 2133 MHz, or change the XMP profile?
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
what to do now.?
Most ram I know of have lifetime warranty if you have receipts I'm sure you can. Send it to be tested
do changing slots make any difference..? i disabled the xmp profile but the problem is still there.!
Not really sure, however some board manuals recommend to fill the slots starting from x1s. If the board happens to be configured such that it expects x1 slots to be filled first, it might cause some issues... I think its worth to try at least.
